Go Back   Ford Forums & Technical Discussions > General Car Discussions > Blue Oval Build Showroom
Old 02-20-2016, 02:24 PM   #161
rangerbill
Pilot
Fan#: 3382
What I Drive: 1998 green ford ranger
rangerbill Good Standing Member
Hey Rick, I finally got my 302 to kick over, blind luck, I ran a jumper wire with a fuse for safety from ignition hot wire to solenoid to get it to crank. it tried to start so I put fuel pump relay back in PJB and she fired up, loud as heck with no muffler but she ran. It still needs wired correctly but it allows me to see any leaks and there were a couple. Its getting there. lol, when she does kick over the truck really kicks. Going to need to get used to the additional horse power. I really like your forum, you give lots of good advice, thanks.
rangerbill is offline
Old 02-28-2016, 03:44 AM   #162
Quote:
Do you have pics of this bad boy?
Old 02-28-2016, 11:59 AM   #163
rangerbill
Pilot
Fan#: 3382
I don't own a smart phone or digital camera so cant download, wish I could, She is running but has a miss? I read on Ranger station that I would have to switch to the in tank fuel regulator from Mountaineer since it runs at 37-45 psi and 3.0 ran at 47-60 psi, I did a fuel press check and she is at 37 psi at fuel rail. So I guess the regulator on fuel rail works. she has spark at all cylinders but runs a lil off, like a miss or vac leak or something? strange thing is when I took the air inlet tube with maf sensor and the air temp sensor off to check something and started it it runs easier, not smoother but idles easier? I wish I could get temp guage to work too, all other gauges work..Thanks for your post, Im hoping to have my toy on the road by spring/ summer
Old 03-11-2016, 07:54 PM   #164
rangerbill
Pilot
Fan#: 3382
Hi guys, I put 3.0 temp sensor on 5.0 and I have temp gauge. I found a couple hoses on egr solenoid crossed, I switched them and she idles pretty nice now. She has gone for a few short cruises and is fun to drive, big difference at pedal of course, well worth all the work
Old 03-11-2016, 09:59 PM   #165
autolite
Senior Pilot
autolite's Avatar
Fan#: 1468
What I Drive: 1998 Black Mustang GT
autolite Excellent Standing Memberautolite Excellent Standing Member
Great, Hope it all goes easy for you to finish it all up.
98 Mustang GT
14 F150 XLT
10 Escape Limited,
06 Harley Ultra Classic
2008 Focus SE
autolite is offline
Old 03-12-2016, 05:25 PM   #166
rangerbill
Pilot
Fan#: 3382
Thanks, I just found a trouble code for the motor running too lean? got to look at that but she runs good til she gets up to 40 mph then hesitates. I wont go that fast for now..lol, but she does have a lot of kick
Old 03-25-2016, 09:00 PM   #167
Sorry for the delayed response, I've been crazy busy. Glad to hear you hot it going. What are the codes you are having?
Old 03-26-2016, 09:43 AM   #168
rangerbill
Pilot
Fan#: 3382
Hi, Ya I know the feeling of crazy busy. She is running fine but I do get a code for tranny, the shift switch ( neutral safety switch) sensor. It says high input which a mech at work says its not grounded? I know that also has an effect on EGR and tranny shifting which she has slightly hard shifts. She was giving codes for both banks running lean but it was actually running rich as hell. I put in a 02 sensor on pass side. all other sensors are showing good readings on his computer. I put in a new EGR, it stuck open and she ran like crap. There is an unspecified code? Trying to fix the tranny one. I had to run a jumper wire from ign switch to neutral safety switch to get it to crank, otherwise it wont? But im having a lot of fun driving her. I don't jump on her hard...yet. She will do 65 uphill fairly easy on parkway which is better than the 3.0, it did 55 with full pedal but no more room to go down.lol. Glad you got back, how is yours running?
Old 03-26-2016, 09:45 AM   #169
rangerbill
Pilot
Fan#: 3382
BTW, codes are 0708 for tranny...0171 and 0174 for the lean thing, and cant remember the other on, might be 1135?
Old 03-26-2016, 10:12 AM   #170
Usually when 0171 and 0174 appear together, it is a vacuum leak. Since both are together, I would also feel it is not a manifold leak, but something like one of the major hoses like PCV valve or brake booster hoses.
HOWEVER... I did chase this down on my Brothers old 2001 Explorer. It turned out that the jackass who owned it before him installed the intake gaskets that are between the head and manifold upside down.
