BODY
Construction: Unitized steel body
Final assembly location: Cuautitlán Izcalli, México
ENGINE
Type: 1.6-liter I-4 Ti-VCT
Manufacturing location: Taubate', Brazil Engine Plant
Configuration: Aluminum block and head
Valvetrain: DOHC, 4 valves per cylinder
Bore x stroke: 3.10 x 3.20 / 79.0 x 81.4 mm
Displacement: 97.4 cu in / 1,596 cc
Compression ratio: 11.0:1
Horsepower: [email protected] 6,350 rpm
Torque: 112 ft.-lb. @ 5,000 rpm
Recommended fuel 87 octane
Fuel capacity: 12.0 gallons
Fuel injection: Sequential multiport electronic
Oil capacity: 4.5 quarts with filter
Coolant capacity: 4.8 quarts (Hot Fill) / 4.4 quarts (Cold Fill)
Emission control: Three-Way Catalyst (TWC)
Federal emissions (tailpipe/evaporation): Tier 2 Bin 4 / LEV II
California emissions states (tailpipe/evaporation): SULEV / PZEV
DRIVETRAIN
Layout: Front-wheel drive
Standard: 5-speed manual
Gear ratios:
1st 3.846
2nd 2.038
3rd 1.281
4th 0.951
5th 0.756
Reverse 3.615
Final drive 4.07 to 1
Optional PowerShift™ 6-speed automatic:
1st 3.917
2nd 2.429
3rd 1.436
4th 1.021
5th 0.867
6th 0.702
Reverse 3.507
Final drive 3.895 for gears 1, 2, 5, and 6. 4.353 for gears 3, 4 and R.
SUSPENSION
Front: Independent MacPherson strut with stabilizer bar
Rear: Twist Beam with coil springs
STEERING
Type: EPAS with power rack and pinion
Ratio: 14.25:1
Turning circle curb-to-curb: 34.4 ft. (15" & 16" wheels)
BRAKES
Type: Power-assisted front disk, rear drum brakes with four wheel, anti-lock braking system (ABS) and AdvanceTrac Electronic Stability Control
Front: 10.2-inch vented disc
Rear: 7.9-inch drum
TIRES AND WHEELS
S sedan: 15-in steel with 6-spoke cover, P185/60R15 BSW
SE: 15-in 8-spoke aluminum alloy, P195/60R15 BSW
SEL sedan: 16-in premium painted aluminum alloy, P195/50R16 BSW
SES hatchback: 16-in premium painted aluminum alloy, P195/50R16 BSW
DIMENSIONS
4-door Sedan
Wheelbase: 98.0
Length: 173.6
Width: 67.8
Height: 58.0
Track front/rear: 57.7/57.7
5-door Hatchback
Wheelbase: 98.0
Length: 160.1
Width: 67.8
Height: 58.0
INTERIOR
Seating capacity: 5
Front headroom: 39.1
Front legroom: 42.2
Front shoulder room: 52.7
Front hip room: 50.6
Rear headroom: 37.1 (37.2 5-door Hatchback)
Rear legroom: 31.2
Rear shoulder room: 49.0
Rear hip room :49.2
WEIGHTS AND CAPACITIES
Total passenger volume (cu. ft.): 85.1 85.1
Cargo volume (cu. ft.): 12.8 N/A
Maximum towing capacity (properly equipped): Not Recommended Not
BASE CURB WEIGHT (POUNDS)
Manual Transmission: 2578 (2537 5-door Hatchback)
Automatic Transmission: 2628 (2575 5-door Hatchback)
Fuel Economy
1.6-liter, 5-speed manual: 29 City/38 Highway (Projected)
1.6-liter, 6-speed PowerShift™ auto: 30 City/40 Highway (Projected)
ENGINE
DRIVETRAIN
Gear ratios:
1st 3.846
2nd 2.038
3rd 1.281
4th 0.951
5th 0.756
Reverse 3.615
1st 3.917
2nd 2.429
3rd 1.436
4th 1.021
5th 0.867
6th 0.702
Reverse 3.507
SUSPENSION
STEERING
Ratio: 14.25:1
BRAKES
Rear: 7.9-inch drum
TIRES AND WHEELS
DIMENSIONS
4-door Sedan
Wheelbase: 98.0
Length: 173.6
Width: 67.8
Height: 58.0
5-door Hatchback
Wheelbase: 98.0
Length: 160.1
Width: 67.8
Height: 58.0
INTERIOR
Seating capacity: 5
Front legroom: 42.2
Rear legroom: 31.2
Rear hip room :49.2
Fuel Economy
