Status
Not open for further replies.
If you have any info you would like to add, PM me or disciplerocks [thumb]
Dana 28 to Dana 35 TTB swap
Dana 35 TTB C-clip eleminator
Dana 44 knuckle swap on Dana 35 beams
In addition to this writeup, another way to bolt on 44 outers is to source a 92-96 full size bronco and grab the spindles out. The spindles on this year bronco (F series trucks of this year do not use the same spindle) have the same bolt pattern as the D35 spindle, so it is literally a bolt on swap [thumb]
Dana 44 solid axle info
General SAS info
Jeep Dana 30 info
Dana 44 swap with leaf springs
Early Bronco Dana 44 SAS swap
Dana 60 info
Ford 7.5/8.8 rear axle info
Explorer 31 spline 8.8 swap
Ford 9 inch info
Dana 28/35 manual hub swap
Permanently lock '98-'00 hubs
Differential, locker, and limited slip info
Ring and pinion setup specs
Status
