· Administrator "Loose Nut"
1965 Ford Mustang, Bandera, Texas
This year I passed down my 1965 Mustang that my mother bought new to my son, it's been in the family since day one. Here's pic of day he picked it up for the 6 hour trek home.
Tire Wheel Car Land vehicle Vehicle
He's had it about a year now and carb is starting to leak and give him issues. So I'm headed to his place for a lesson in carb rebuilding and thought I would do a short breakdown of process that I'm talking my son thru. Motor is a 351w stoked to 393. Carb is a Barry Grant Demon 750.
First we clean everything up good. I like starting with a clean engine.
Hood Automotive tire Motor vehicle Automotive care Automotive design
Carb removal is easy, fuel line, a few vacuum lines, throttle linkage and the four bolts to manifold. There's no transmission kickdown as it got a manual shift automatic.
Hood Motor vehicle Car Automotive fuel system Automotive design
Gas Machine Auto part Fashion accessory Metal
Removed the bowls, four bolts holding each one on rear had some gunk in it, accused him of driving like "Miss Daisy" and not opening the secondaries often enough.
Wood Finger Engineering Nail Machine
Motor vehicle Gas Automotive exterior Auto part Bicycle part
The front looked good.
Gas Machine Auto part Metal Nickel
The metering blocks were clean.
Gas Rectangle Auto part Composite material Metal
Bowls looked good. You can see tear in upper left gasket. Looks like I over tightened last time I had it apart.
Rectangle Gas Auto part Electric blue Wood
Here's everything laid out.
Circuit component Passive circuit component Electrical wiring Wire stripper Office equipment
This is where we stopped. It's one of my granddaughters birthday so that took priority. We'll finish tomorrow.
Got the carb build done.
Got the body cleaned up well. Used brake cleaner and compressed air to get rid and of crud and made sure all passages were clear.
Hand Automotive tire Camera accessory Gas Asphalt
Then cleaned metering blocks the same way.
Gesture Nail Finger Line Thumb
Metering blocks reassembled with new parts, old parts are in front. We counted turns in on air needles and set them the same.
Sleeve Tool Wood Gas Font
All together. We measured old float level before disassembly and installed new float needles the same.
Gas Machine Auto part Nut Fashion accessory
Installed back in car.
Automotive fuel system Hood Motor vehicle Automotive design Vehicle
Cranked right up once bowls had fuel. Checked for leaks, had to adjust idle slightly, checked float level thru bowl windows, was dead on,
Light Automotive tire Motor vehicle Locking hubs Vehicle brake
adjusted air screws to highest vacuum, my preferred way, set idle, double checks for leaks, then text drive. I'm proud of my son, he did it all, he's all smiles, didn't even get my hands dirty. On test drive low end is great. Then went on top end test, did a 75 to 90 mph pull, no fuel starvation, all good.
I sure do love this car. May not be mine anymore after 57 years, but my son gets to enjoy it for hopefully many years to come and possibly generations to come with the grandkids.
