1 - 20 of 105 Posts
Discussion Starter · #1 · (Edited)
Current parts and mods
4.0 OHV from a 94 Explorer
A4LD/5R55E hybrid, rebuilt, shift kit, oversized pan
1354/1354 doubler
Explorer front driveshaft for rear
Explorer Sport rear driveshaft for front
High pinion dana 44, Helical LSD, 4.56 gears, Warn lockouts, Single spindle nut setup, Poly bushings
Full width 31 spline 8.8, trussed, spooled, 4.56 gears, disc brake swap
F250 brake master cylinder
2" drop shackles and stock Ranger 2" lift blocks
Repacked Explorer leafs
6" Rough County XJ coils
35" Baja Claws
9k winch
130 amp alternator
On board air
Exo in process
Dana 60/Sterling swap in process
Wheelbase - 99.75"
Crawl ratio - 69.27:1
RTI - 924
So here she is, my $700 B2.
Budget lift
Real lift
Broken D28, and the new D35 with 3.73s
Old 7.5 and new 31 spline 8.8 with L/S 3.73s
Old steering with lift
New ZJ steering setup
Stonecrusher radius arm extentions
Sliders
New rear bumper
New front bumper
Diff protector
More to bumper
4.0
4.0 in its new home.
Idle video
Half door
New tires
Caught on fire
Installed high lift
F250 shock towers
New D35 and 8.8 with 4.56s already installed
Aussied the front, welded the rear
Fenders cut for flexy XJ springs
D35 maxed out
And the flop
F250 master cylinder
New steering
Tube fenders
And then came the doubler
First trail after doubler I blew both hubs and cracked a lift bracket.
So I came across a high pinion D44 with 4.56s already installed.
One day solid axle swap
Then came the full width 8.8
Welded tubes, installed an Explorer disc brake setup with redrilled rotors, and installed a mini spool
Then the FM146 couldn't hold the 4.0 anymore. Rebuilt A4LD with oversized pan, shift kit, and 5R55E drum, pump, starter and bellhousing.
Auto ready to go in
New 8.8 in, moved back 3"
Fender cut
I got lucky. I had a passenger and no doors at the time.
Meh.
That post took awhile to make! Glad I saw this thread. I always had wondered what your bronco looked like. I hope we turn the jeep we have into a trail rig...otherwise I always wanted a Bronco.
Picked this up today. Its some kind of helical l/s out of a Dana 44 Jeep rear with 4.55 gears. It does not look like a stock Jeep unit. It looks like a Detroit, but not exactly.
Did you get it done? I just got finished rebuilding John's front 60 (again). His pinion was loose again. I found out who ever set up his gears the first time didn't do it right. Luckily its just his trail only truck and didn't have high miles or high speeds put on it. The last guy who changed his yoke messed up the threads on the pinion. Turns out they replaced the nut with the wrong one. John got another nut but was the wrong one as well. I ended up cutting about 3 threads off the pinion (they would have chewed up any other nut going on) and re-installed everything with a new, correct nut. He will need a new ring and pinion next time its taken down. Gear pattern is way off, but John decided to just run it as it is, which will likely be 2 or 3 more rides, and he will be getting a new R&P as well as an E locker. We also found it has GM spindle nuts. So a set of Stage 8's are on the list as well....
I will be finishing it up today. I'm running to the new Liberty yard this morning. Had a buddy tell me there is a Chevy 44 with factory drive flanges on it. So I'm going to go nab them.
Replaced the inner axle seals while I was in there. No more fluid pouring onto the ground everytime I am off camber.
Also swapped to the single spindle nut setup. Lets see how it does.
Stage 8's are the way to go. The single style you have gone with are better than the stock setup, but can be a pain and troublesome to remove when you need to service...
Man, its all bad. Its dark, its blurry and there is a whitle squiggly line in the background, looks like overexposure [:D]
Where's the plow?
1 - 20 of 105 Posts
