Ford Fiesta
Exterior Dimensions
Wheelbase [in]: 98
Length [in]: 173.6 - 160.1 (5-Door Hatchback)
Height [in]: 58
Width - Excluding Mirrors [in]: 66.8
Width - Including Mirrors [in]: 77.8
Width - Mirrors Folded [in]: 71.6
Weight [lbs]: 2578 (Manual Transmission) - 2628 (Automatic Transmission)
Weight [lbs]: 2575 (Manual Transmission 5-door Hatchback) - 2628 (Automatic Transmission 5-door Hatchback)
Front Track [in]: 57.7
Rear Track [in]: 57.7
Powertrain Specifications
Engine Type: 1.6L 16-valve Duratec® I4
Horsepower: 119 hp @ 6000 rpm
Torque: 109 lb-ft @ 4000 rpm
Drive Type: FWD
Transmission Type: Std. 5-speed manual/Opt. PowerShift 6-speed automatic
Engine Electronics: Twin-Independent Variable-cam Timing (Ti-VCT)
Compression Ratio: 11:01
Valve Lifters: 16-valve
Fuel Delivery: MFI
Engine block material: Aluminum Alloy
Fuel Economy: 28/37 (Manual Transmission) - 29/40 (Automatic Transmission)
0-60 MPH: 10.1 Seconds
1/4 Mile: 17.5 Seconds
Mazda2
Exterior Dimensions
Wheelbase [in]: 98
Length [in]: 155.5
Height [in]: 58.1
Width [in]: 66.7
Weight [lbs]: 2306 (Manual Transmission) - 2359 (Automatic Transmission)
Front Track [in] : 58.1
Engine Type: 1.5-liter DOHC 16-valve 4-cylinder with VVT
Horsepower: 100 hp @ 6000 rpm
Torque: 98 lb-ft @ 4000 rpm
Drive Type: FWD
Engine Electronics: Chain-driven dual overhead cams, 4 valves per cylinder with variable intake valve timing (VVT)
Compression Ratio: 10.0:1
Fuel Delivery: MFI
Fuel Economy: 29/35 (Manual Transmission) - 27/33 (Automatic Transmission)
0-60 MPH: 9.1 Seconds
1/4 Mile: 16.9 Seconds
Exterior Dimensions
Wheelbase [in]: 98
Height [in]: 58
Drive Type: FWD
Fuel Delivery: MFI
Mazda2
Exterior Dimensions
Wheelbase [in]: 98
Length [in]: 155.5
Height [in]: 58.1
Width [in]: 66.7
Drive Type: FWD
Fuel Delivery: MFI
