1 - 7 of 7 Posts
They can be a pain, the longer you wait, the worse they are. My advise is to partially fill the holes with WD40 or PB blaster, let em soak for 5 minutes, then slowly break em loose. The WD40/pb blaster is flammable, so it won't hurt the cylinders if they leak down in there...
Thanks man had not thought about doing that. I am just not looking forward to it. It one of those things that I have been wrenching for years and I hate working on my own stuff now...lol
Btw, make sure to put antiseize on the new plugs...
My 5.4 has 231000 miles on it and its probably about due new plugs. I know I havent changed them since I had the truck. Except for 1 lol. It got changed a while back when I dropped a coil pack. Which by the way I'm still on 5 of my original coil packs. Dont know if thats something to brag about or if I need to change them asap. I figure just run them until they go out and soon I should have all new ones.
The breaking plugs issue was only on the 3v 5.4's from 04-early 08. from mid 08-on ford redesigned the heads and plugs therefor solving the issue.
BTW the 4.6 3v used in the mustangs and explorers had the same problem.
On a side note, tech's at the dealership have had good success with using an cordless 1/4" or 3/8" impact. Just blow out the plug well with air and use a socket and cordless impact and let er rip. For some reason the 1/4" or 3/8" impact has enough tq to get the plugs out before they seize and break but not enough tq to strip the threads in the head.
1 - 7 of 7 Posts
