disciplerocks's 5.0 V8 rebuild/supercharged thread
356K views 346 replies 7 participants last post by  disciplerocks
#1 · (Edited)
Link to original thread:http://www.blueovalfanatics.com/forum/showthread.php?t=21454
So I finally get the car together and running. Been taking it to a few local shows after FF13. So what to do now? Tear it all apart of course!
Current state:
Stock 95 5.0 HO
95 F150 ECU
Foxbody upper intake
MSD cap, rotor, and coil
Massive plug wires
Build plans:
97 Explorer block (have)
Forged internals (have)
GT40 heads (have)
1.6 roller rockers (have)
Wolverine cam (have)
Explorer OBDII wiring harness (have)
Distributorless swap (have)
Coil on plug (have)
4.6 ECU (have auto, need manual)
F150 lower intake (have)
M90 Eaton supercharger (have)
Still need head gaskets, Mustang oil pan and pickup, and to custom make a whole new wiring harness.
Current parts and mods 8/10/14
EXTERIOR:
Roush Front Bumper
SVT Rear Bumper
SVT Side Skirts
SVT Wing
European Grill
European Hood Latch/Lock
European Fuel Door
European Tail Lights
INTERIOR:
SVT Blue Insert Leather Seats
SVT Pedals
ST170 Gauge Cluster
ST170 Dome Light
European Rear Dome Light
European HVAC Controls
European Door Handles
European Radio Surround
European Shifter Surround
European Lower Dash Pocket
Adjustable Short Throw Shifter
2011 Focus Shift Knob
POWER & PERFORMANCE:
96 Explorer 5.0 Block
97 Explorer Harness and ECU
T5 Transmission
Hydraulic Slave Conversion
4 Lug Open Diff 7.5 with 3.73 Gearing
BBK Adjustable Fuel Pressure Regulator
Bahnhof Stage 2 Clutch
Billet Flywheel
Speed Pro Pistons on Foxbody Rods
Wolverine/Blue Racer Cam
Double Roller Timing Chain
97 Explorer GT40 Heads
Pro Comp 1.6 Aluminum Roller Rockers
Hardened Pushrods
Pro Comp Head Studs
GT40 Upper and Lower Intake
Coil on Plug Conversion with 4.6 Coils
Raptor 2.5" Mufflers
Dual SVT Fuel Pumps
Relocated Battery and Fuel Tank to Hatch
STEERING & SUSPENSION:
KYB GR-2 Struts
Tein S-Tech Springs
Foxbody Rack & Pinion
Moroso Bump Steer Kit
Mustang Rear Sway Bar
Custom Strut Tower Brace
Custom Rear Stress Brace
WHEELS, TIRES & BRAKES:
ST200/Turbine Wheels
Drilled and Slotted Front Rotors
Rear Disc Brake Swap
#2 ·
In. You can use the oil pan/pickup tube from the 95 when you pull it. You may have an issue using the 4.6 ECU, the 4.6 has two cams, and IIRC two cam sensors, one for each cam. Also, going boosted, as you know, you will need to tune it since it'll he OBD2, you can remove the auto trans with the tune...
#3 · (Edited)
I'm still having drivability issues with with the current setup, so I figured I would just complicate it [hihi]
Now on to the pictures.
Current state
Explorer block
Partial teardown
Distributorless electronics (maybe an intercooler)
GT40 heads
Foxbody rods and Speed Pro pistons
4.6 ECU
F150 lower intake (larger runnersand AIT in manifold)
COPs
M90
#4 ·
You think it would be easier to stay OBDI? Or maybe I'll throw it all out and go carb lol. There's an F150 at Glisson's with a 4 barrel intake.
#5 ·
I'd go completely ex 5.0 ignition system. It will solve your dizzy clearance problem, solve your driveability issue, and has less components. When you get a tune (you know your getting one, its only a matter of time) it will be easier since you won't have mix-matched parts. I've been thinking of doing cop, but it would make mounting with headers difficult...
#6 ·
I can run coil packs with an OBDI setup. Maybe I should just do that, since it was my original plan. Just wish I knew what was causing my problems now so I'm not running into them again with the new motor.
#8 ·
Not really looking to spend several hundred in tuning again.
Let me weigh my options and see if I can figure out what my current problem is.
#9 ·
When you boost, you need to tune so you don't blow the motor, you know that. You can do basic tuning yourself with the wideband, adjusting fuel pressure, different injectors, and bigger maf/tb/air filter...
#12 ·
So I picked up some lifters today since they were missing on my motor. Installed my cam and double roller timing chain. Also threw a coat of semi-gloss on the block.
#16 ·
Pulled out my Ex harness and labeled everything using the Mountaineer as a guide while I still have it. Guess I won't need the other half of the harness.
#17 ·
Got the other head drilled and tapped.
Threw some paint on the lower.
Also I forgot that I picked these up Saturday.
#18 ·
Yes it has both the ecu temp sensor and the gauge sensor. The plus is the air temp sensor is in the manifold as well. So the ecu will get a more accurate temp reading post blower.
#19 ·
Pushrods ordered and I picked up my torque wrench. Tried to torque my rods in so I can move to the top half, but after doing so the crank won't turn. Turns fine with them loose. Get to look into that tomorrow.
And I am fairly certain I blew a head gasket on the Mountaineer. Drove to work fine and most of the way home. Then about 1/2 mile from home the temp gauge started creeping up. Then it died and I pulled over. Gauge never got over 3/4 high. I let it cool and tried to start it. Nothing.
What a day.
#20 ·
Dustin, pull a main cap and read the bearings, if they are anything but standard (0.010, 0.020, 0.030, etc) that is your problem. If you have a set of calipers, measure the crank diameter and verify...
Check coolant and oil, if either is mixed, its the gasket...
#22 ·
No coolant = blown head gasket, possibly warped/cracked head...
Do you have the timing chain on while trying to turn the crank after torqued caps? Possible that's something on top one of the pistols?
#23 ·
No timing chain, no heads. Turns fine with the rod bolts cracked loose a little. Something is in a bind. Going to do one at a time to find out which.
