21 - 40 of 232 Posts
Discussion starter · #21 ·
The MN-12 platform t-birds and cougars and MK 8's from 89-97 used 5x4.25 or 5x108mm, and the taurus/sable twins up to 2007 used the same, the rebadged 500 they called the taurus in 08 had 5x4.5 or 113mm. Also the mk3 focus from 2012 and up uses the same pattern along with the new escape 2013-up and the new fusion and MKZ. You can get up to 19" wheels from a 13-up escape, fusion ,or mkz. 18's from a focus.
That's what I meant, I should have been more clear in my post. You proably thought i meant the focus uses 5x114, after rereading my previous post, I can see how I was misunderstood.
Oh and in case you did not know, 5x 4.25" and 5x108mm is the same thing. Just like the bigger mustang pattern is 5x4.5" or 5x114.3mm
Discussion starter · #26 ·
Discussion starter · #27 ·
Tristate bearing doesn't have anything. I was told to try Jasper Engines. Guess I'll give them a call.
Discussion starter · #31 ·
I have found a couple that are close. Had one that might work, but I would need to find a bushing to put it in.
Discussion starter · #34 ·
I've seen several while doing research for my swap. No thanks, I'll stick with a solid axle. I've never been a fan of CVs.
Discussion starter · #36 ·
Did some measuring today.
31 spline bearing area
31 spline non-bearing area
28 spline bearing area
28 spline housing
Discussion starter · #37 ·
Also took a second look at the 97+ 8.8 brakes. The rotors are bigger making 15s not fit, but it appears that the brake pad surface area and calipers are the same size as the Explorer so no benefit there. Only plus side is the hubs are larger so regular full size shafts will fit.
Discussion starter · #39 ·
Just talked to the lead journeyman in our tool room at work. Asked him if he would show me how to use the lathe. He said just bring him what I had and he would take care of whatever I needed. Looks like I am making another trip to Glisson's this week and piecing together my axle. Then bringing the shafts in to work and turning down the bearing area to fit the 28 spline housing.
Lathes are actually pretty simple to operate. You can usually find them on Craigslist for decent price. They have unlimited uses for guys like us...
